Problem running GRIP program in NX9
Hi All,
We have a GRIP program used function &MCSARR it works fine in NX6 but got error message "Invaild operation type" when used in NX9. Having checked the GTAC found there is PR 6829672
reported this problem before and said will be solved in NX8.5.2 and NX9 but I still get the same problem in NX9.
Does anyone has same problem and any workaround?
Terry
