Problem with getting 'Time parameter' of a tool/operation
Siemens Creator
Recently i am try to add some functionality to my app (i wrote app that work on top of nx)
for this purpose i need to extract/get the 'Time' parameter from the "Operation Navigator View" from the nx
but for know without success, will be glud for any ideas.....thanks!
*** ATTACHING PICTURE FOR WHAT I NEED ***
Re: Problem with getting 'Time parameter' of a tool/operation
I think that you will need to sum the times reported for each operation to arrive at the total. Below is a link to some code on the GTAC solution center that shows how to iterate through the operations and get the time values.
http://solutions.industrysoftware.automation.siemens.com/view.php?si=nx_api4897
The times (cuuting and non-cutting) are stored as operation parameters.
Like @cowski1 says, if you want them for a group, as seen inthe Operation Navigator, you need to add them up in your program.
Mark Rief
Retired Siemens
