Query 4G Design data with NXOpen?
Can you query 4G Design Data using NXOpen? Specifically I want to be able to get Design Elements. In my experience it seems you can only gather information based on your current NX session. So if that is the case, I would probably need to load Design Elements in NX to query them correct?
Is it possible to get them using just there corresponding 3G part?
