Query an element thickness
Hi,guys!
    I can't query the element thickness using ThicknessBuilder.GetElementThickness. The element is created by ElementCreateBuilder.
Can anybody help me? Thank you!
Email:zhuzhenwei95@gmail.com
Re: Query an element thickness
For some reason if you instantiate one thicknessbuilder, it will return all 0.0 values for the thickness. However, if you instantiate a "dummy" thickness builder, then destroy it, then instantiate another builder, it will return the correct thickness values.
Thanku!
I have solved this problem. I need to clear the thickness builder before destroy it.
