Query assembly attributes without loading it
Hello, I am wondering if it is possible to query an assembly for attribute data without it being fully loaded. The assembly is very large, and I cannot open the entire thing in NX. However I need to walk through the assembly and get the names of each component. Can I do this without loading the entire thing?
Re: Query assembly attributes without loading it
I know that interactively you can load structure only your large assembly and get component information.  I have not had a need to do this programming but seems to me to be possible.
Frank Swinkels
Once you have the component file list of your assembly use 'UF_ATTR_ask_part_attrs_in_file' fundtion to get attributes without opening the part file.
Suresh
