Questions about PMI
hello all
How to get annotation plane in PMI,Study for many days, no results
Hope to have a .NET example or pointing
Re: Questions about PMI
@MRone: You can use 'User Defined' annotation plane from the orientation. Check the other available options which suits best to your need.
Ganesh
Thangks
but I did not find this dialog
NX8.0
I am not sure of this option in NX 8. It may be introduced in some later release of NX.
EDIT: 'PMI Rapid Dimension' is available from NX 9 and it has 'Origin Group Options' with orientation option to select the user defined annotation plane. Prior to NX 9, it was 'Inferred dimension'.
Ganesh
