Reference and Arrangement listing within all components
Has anyone found a way or customized a Journal code to list out per component (assembly and part) all the reference sets and arrangements available, not just the ones in use?
So it may result in an output like this:
Component 163885 Path: 10461510-1/A1 Reference Sets: Model, ALR, Simple
Component 65051 Path: 10461549-1/A1 Reference Sets: Model
Component 65059 Path: 10461550-1/A1 Reference Sets: Model
Where each line shows the component and a list of the reference sets available within each component.
And that also would follow suit with arrangements as well…
Component 163885 Path: 10461510-1/A1 Arrangements: Open, Closed, Stowed
Component 65051 Path: 10461549-1/A1 Arrangements: Open
Component 65059 Path: 10461550-1/A1 Arrangements: Arrangement 1
This customized code exists (see below) for listing out the reference sets for the work part, but I would need to spend some learning time to figure out how to adapt it to pull this kind of info for every part and subassembly. I'm hoping folks may have something already done or at least more towards that result.
Thanks!
Option Strict Off
Imports System
Imports NXOpen
Module report_reference_sets_in_workpart
    Sub Main()
        Dim s As Session = Session.GetSession()
        Dim workpart As Part = s.Parts.Work
        Dim lw As ListingWindow = s.ListingWindow
        lw.Open()
        Dim refSets() As ReferenceSet = workpart.GetAllReferenceSets
        For Each refSet As ReferenceSet In refSets
            lw.WriteLine(" Reference Set: " + refSet.Name)
        Next
    End Sub
    Public Function GetUnloadOption(ByVal dummy As String) As Integer
        GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately
    End Function
End Module
Re: Reference and Arrangement listing within all components
Try the following journal. The arrangement/ref set in use is marked with an asterisk *.
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Imports NXOpen.Assemblies
Module Module1
    Dim theUfSession As UFSession = UFSession.GetUFSession()
    Dim theUI As UI = UI.GetUI()
    Dim lw As ListingWindow = theSession.ListingWindow
    Sub Main()
        Dim markId1 As Session.UndoMarkId
        markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "NXJ")
        lw.Open()
        lw.WriteLine("Assembly: " & theSession.Parts.Display.Leaf)
        Dim c As ComponentAssembly = theSession.Parts.Display.ComponentAssembly
        If Not IsNothing(c.RootComponent) Then
            '*** insert code to process 'root component' (assembly file)
            Dim theArrangements() As Arrangement = theSession.Parts.Display.ComponentAssembly.Arrangements.ToArray
            If theArrangements.Length = 0 Then
                lw.WriteLine("  no arrangements")
            Else
                lw.WriteLine("  Arrangements:")
            End If
            For Each tempArr As Arrangement In theArrangements
                If tempArr.Equals(c.RootComponent.UsedArrangement) Then
                    lw.WriteLine("    * " & tempArr.Name)
                Else
                    lw.WriteLine("    " & tempArr.Name)
                End If
            Next
            '*** end of code to process root component
            reportComponentChildren(c.RootComponent, 1)
        Else
            '*** insert code to process piece part
            'lw.WriteLine("Part has no components")
        End If
        lw.Close()
    End Sub
    Sub reportComponentChildren(ByVal comp As Component, ByVal indent As Integer)
        For Each child As Component In comp.GetChildren()
            '*** insert code to process component or subassembly
            lw.WriteLine(New String(" ", indent * 2) & child.DisplayName())
            Dim isLoaded as Boolean = False
Try If child.Prototype.OwningPart.IsFullyLoaded Then 'component is fully loaded
                    isLoaded = True Else 'component is partially loaded
                    isLoaded = True End If 'report reference sets lw.WriteLine(New String(" ", indent * 2) & " Reference sets:") For Each tempRefSet As ReferenceSet In child.Prototype.OwningPart.GetAllReferenceSets If child.ReferenceSet = tempRefSet.Name Then lw.WriteLine(New String(" ", indent * 2) & " * " & tempRefSet.Name) Else lw.WriteLine(New String(" ", indent * 2) & " " & tempRefSet.Name) End If Next Catch ex As NullReferenceException 'component is not loaded lw.WriteLine(New String(" ", indent * 2) & " component not loaded")
isLoaded = False End Try '*** end of code to process component or subassembly If isLoaded andAlso child.GetChildren.Length <> 0 Then '*** this is a subassembly, add code specific to subassemblies Dim theArrangements() As Arrangement = child.Prototype.OwningPart.ComponentAssembly.Arrangements.ToArray If theArrangements.Length = 0 Then lw.WriteLine("no arrangements") Else lw.WriteLine(New String(" ", indent * 2) & " Arrangements:") End If For Each tempArr As Arrangement In theArrangements If tempArr.Equals(child.UsedArrangement) Then lw.WriteLine(New String(" ", indent * 2) & " * " & tempArr.Name) Else lw.WriteLine(New String(" ", indent * 2) & " " & tempArr.Name) End If Next 'lw.WriteLine(New String(" ", indent * 2) & " + Active Arrangement: " & child.OwningPart.ComponentAssembly.ActiveArrangement.Name) '*** end of code to process subassembly Else 'this component has no children (it is a leaf node) 'add any code specific to bottom level components End If reportComponentChildren(child, indent + 1) Next End Sub Public Function GetUnloadOption(ByVal dummy As String) As Integer 'Unloads the image immediately after execution within NX GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately '----Other unload options------- 'Unloads the image when the NX session terminates 'GetUnloadOption = NXOpen.Session.LibraryUnloadOption.AtTermination 'Unloads the image explicitly, via an unload dialog 'GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Explicitly '------------------------------- End Function End Module
Edit (2018-02-12): fixed a null reference bug (the code tried to access arrangement info even if the component part wasn't loaded)
Thank you!
I realized those insert code were just comments. I attempted to run the code as C# code and not Visual basic.
When I ran it I got this error... Have any idea's what this might mean?
Also it outputs for a while but must hit a component that causes this error to happen.
Nevermind I found it was caused by components being suppressed and/or not loaded at all Smiley Happy
Worked like a charm! Thanks so much!!
If the part isn't loaded, you don't want to attempt accessing the arrangement info (this is a bug in the original code). Try something like the code below:
            lw.WriteLine(New String("", indent * 0) &"-:FILE:-" & child.DisplayName()&"-:FILE:-")
            Try
                    isLoaded = True
                Else
                    isLoaded = True
                End If
                lw.WriteLine(New String("", indent * 0) & "--Reference sets:")
                        lw.WriteLine(New String("", indent * 0) & "" & tempRefSet.Name)
                    Else
                    End If
                Next
                lw.WriteLine(New String("", indent * 0) & "--Component not loaded:")
                isLoaded = False
            End Try
                Else
                    lw.WriteLine(New String("", indent * 0) & "--Arrangements:")
                End If
                        lw.WriteLine(New String("", indent * 0) & "" & tempArr.Name)
                    Else
                    End If
                Next
                'lw.WriteLine(New String("", indent * 0) & " + Active Arrangement: " & child.OwningPart.ComponentAssembly.ActiveArrangement.Name)
            Else
            End If
            reportComponentChildren(child, indent + 0)
        Next
    End Sub
I tried it and unfortunately came back with this.
Much appreciated for taking time again to adjust the code for me. :-)
I was playing around with very little knowledge and added the Try and Catch around the lower "If child.GetChildren.Length <> 0 Then" statement. It double listed the "--Component not loaded:" statement so I commented it out and it appears to list out ok with no crash.
It appears to work, unknown why though :-)
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Module Module1
    Sub Main()
        lw.Open()
            Else
                lw.WriteLine("Arrangements:")
            End If
                    lw.WriteLine("" & tempArr.Name)
                Else
                End If
            Next
        Else
        End If
        lw.Close()
    End Sub
            Try
                Else
                End If
                    Else
                    End If
                Next
            End Try
            Try
                Else
                End If
                    Else
                    End If
                Next
            Else
            End If
                'lw.WriteLine(New String("", indent * 0) & "--Component not loaded:")
		End Try
        Next
    End Sub
    End Function
End Module
Oh my apologies I see what happened on the code you placed.
It was only a portion of the original code. I swapped that section out and it worked out. Sorry about that.
Here's the whole set of code with that section swapped in case anyone else copies out the code for use.
Also attached the excel sheet again. With the addition of code listing unloaded sub-assemblies I had to make one small change to it.
@cowski1 Thank you again!
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Module Module1
    Sub Main()
        lw.Open()
            Else
            End If
                Else
                End If
            Next
        Else
        End If
        lw.Close()
    End Sub
            Try
                    isLoaded = True
                Else
                    isLoaded = True
                End If
                    Else
                    End If
                Next
                isLoaded = False
            End Try
                Else
                End If
                    Else
                    End If
                Next
            Else
            End If
        Next
    End Sub
    End Function
End Module
