Regarding the accuracy of measurement data of BoundingBox
Hi all
I found sometimes the accuracy of measurement data of "BoundingBox" was not exact, do we have other way to measure the maximun size of solid body?
If I use surface select and not use function "boundingBox", it will spend lot of time.
Best Regards
Christian
Re: Regarding the accuracy of measurement data of BoundingBox
Try UfModl.AskBoundingBoxExact.
Suresh
It's worked. Thanks for your suggestion.
Best Regards
Christian
