Remove Component Group
How can I remove Component Group (test in the picture) inside Component Groups in Part? I can remove all the components within the group but not group itself.
I use Java, but if you point to an interface/method it is fine without the example.
Please let me know,
Alen
Re: Remove Component Group
We used to call these "component sets".  We have an example program (Open C) on the Solution Center, and you should find it right away if you search for this string:
DELETE_SPECIFIED_COMPONENT_SET
It cycles for objects in the part of type UF_component_set_type, and then checks the name of each one.  When it finds the right one, it deletes it with UF_OBJ_delete_object().
