Replace Reference Set
Innovator
Innovator
Here my code
foreach (String str in identifiers)
Component comp = (Component)theSession.Parts.Work.ComponentAssembly.RootComponent.FindObject(str);
theSession.Parts.Work.ComponentAssembly.ReplaceReferenceSet(comp, "BODY");
How come when i implment this it leaves all the components that are in the list of "identifiers" untouched.
It finds them, It just doesn't change the reference set of any of the selected components to "BODY". Is there something else I should be Calling?
Re: Replace Reference Set
Do these components have a "BODY" reference set?
The default reference set for solids that NX creates is named "MODEL".
Production: [NX8.5.3.3 MP11 64bit] Testing: [NX12.0.0.27 MP1]
Were you able to get this to work?
Are the components of interest top level components in the workPart? If not, try {component var}.DirectOwner.ReplaceReferenceSet(...)
