Replace constrained component
When I try to replace a constrained component, it shows alert in the related constraint and the status of the constraint shows " This constraint cannot solve. Either it references a component that has
been deleted or suppressed, or it references geometry that has been
deleted, suppressed, or is now of the wrong type". If I set the maintainRelationship property to false,I lost the constraint. Any suggestions to solve this issue.
Thanks.
