Replace master sheet
starting to NX8, we start to use title block in drawings in replace to patterns. Thanks to some programmers in the forum, we have obtained a journal that replace old patterns in drawings to new title block. Also on drawing dimension change, for example from A3 to A2, replace and correct the title block position.
Today I've add line in template to aid folding the paper like the image attachedline to folding.png
, so for new drawings, we have those line, but when I use the journal, for old drawing, those line are not present. Attache the journal and a template. Can someone help me to adjust the journal ?
Thank you...
Using NX1867
RuleDesigner PDM
