Routing Cable Library
I have a problem conecerning the Routing Part Libraries. I want to add diffenrent types of cables to the library. The last time i tried serveral ways. First I add a line in the right ptb-File e.g. circular_stock_mm.ptb. After a restart of NX the new cable wasn't there. Then I tried to add a line in the part family e.g. cir_cable02.prt, but here the same problem. I can add a line in the spreadsheet but I need to save the child part somewhere. The point i don't understand is that the existing parts of the family are not in the installation folder.
Can me please someone explain how to build-up cable libraries? for wires it wasn't a problem.
Thank you in advance.
Kind regards,
