Run UG_IMPORT ignoring missing dependencies
Builder
Builder
I have a new NX assembly having more than 300 components. Few components are missing, i would like to import the assembly into teamcenter ignoring the missing components and missing dependencies if any.
I am using a mapping file to import other assemblies and drawings successfully.
How do i instruct the utility to ignore the missing components and import the rest into Teamcenter? I am fine if Item and Item Revision is created and dataset is not imported.
Santosh
