Running executable via NX command prompt through an Excel Macro
I am trying to run a .exe file through NX command prompt and I would like to do it through excel. I know that you can run an executable through an excel macro using the following code
Sub LaunchExecutable()
RetVal = Shell("File Path here", 1)
End Sub
 However for using NX's CMD line I have no idea how to accomplish this.
Any help wpuld be appreciated.
Re: Running executable via NX command prompt through an Excel Macro
call batch file that calls ugiicmd.bat then your executable
or set required env using
Environment.SetEnvironmentVariable(envName, envValue)
