SNAP Blockstyler Error
I have been getting the following error:
Unhandled exception encountered in call back automation code.
 This seems to occur if I exit out of the dialog, re-enter the dialog, and then click either OK or apply. If I switch to the modeling application and back to the drafting application, the file will run with no errors.
The NX log shows:
&MACRO OK 0 0 ! OK Callback
*** EXCEPTION: Error code  3520041 in line 78 of D:\workdir\Reference\NX903_4\src\part\no\ind\jax_property_container.cxx at Thu May 28 10:23:43 2015 Eastern Daylight Time
+++ Property "BlockID" does not exist for block name ""
Any thought to what I did wrong?
The code:
Option Infer On
Imports Snap, Snap.Create
Imports NXOpen, NXOpen.UF
Imports System
Public Class qPlot : Inherits Snap.UI.BlockForm
    Dim theUfSession As UFSession = UFSession.GetUFSession()
    Dim displayPart As Part = theSession.Parts.Display
    Dim strPlotter As String()
    ' Declarations of the blocks on a qPlot dialog
    Dim blkPlotter As Snap.UI.Block.Enumeration
    Dim blkPaper As Snap.UI.Block.Enumeration
    Dim blkRefresh As Snap.UI.Block.Button
    ' Constructor for the qPlot dialog object
    Public Sub New()
        Me.Title = "Nexteer qPlot"  ' Text to be shown in title bar of dialog
        Me.Cue = "Please select Plotter and Size"   ' Text to be shown in cue line
        ' Create an Enumeration blocks (Plotter and Paper)
        blkPlotter = New Snap.UI.Block.Enumeration()
        blkPlotter.Label = "Please select a Plotter"
        Dim strPlotterList As String = ""
        Try
            strPlotterList = GetSetting("NX journal", "qPlot", "PlotterList")
        Catch ex As Exception
        End Try
        If strPlotterList.Length < 1 Then
            GetPlotterList()
        Else
            strPlotter = Split(strPlotterList, "::")
            blkPlotter.Items = strPlotter
        End If
        blkPaper = New Snap.UI.Block.Enumeration()
        blkPaper.Label = "Please Select A Plot Scale"
        blkPaper.Items = {"Full (1:1)", "Half (2:1)", "Other (11in Roll)"}
        ' Create a Button block
        blkRefresh = New Snap.UI.Block.Button()
        blkRefresh.Label = "Refresh Plotter List"
        ' Add all the blocks to the BlockForm
        Me.AddBlocks(blkPlotter, blkPaper, blkRefresh)
    End Sub
    Public Shared Sub Main()
        ' Create and display a qPlot dialog
        Dim myForm = New qPlot()
        myForm.Show()
    End Sub
    Public Overrides Sub OnShow()
        ' Code for when dialog is displayed
    End Sub
    Public Overrides Sub OnOK()
        ' Code for when user clicks OK
    End Sub
    Public Overrides Sub OnApply()
        PrepPlot()
    End Sub
    Public Overrides Sub OnCancel()
        ' Code for when user clicks Cancel
    End Sub
    Public Overrides Sub OnUpdate(changedBlock As Snap.UI.Block.General)
        If changedBlock = blkPlotter Then
        ElseIf changedBlock = blkPaper Then
        ElseIf changedBlock = blkRefresh Then
            GetPlotterList()
        End If
    End Sub
    Public Sub GetPlotterList()
        Dim intPrinters As Integer = 0
        theUfSession.Plot.AskPrinterNames(intPrinters, strPlotter)
        Dim strNewPlotterList As String = strPlotter(0)
        For i = 1 To strPlotter.Length - 1
            strNewPlotterList = strNewPlotterList & "::" & strPlotter(i)
        Next
        SaveSetting("NX journal", "qPlot", "PlotterList", strNewPlotterList)
    End Sub
    Public Sub PrepPlot()
        Dim strPlotter As String = blkPlotter.SelectedItem
        Dim intSelectedSize As Integer = blkPaper.SelectedIndex
        ' Get user name
        Dim strUserName As String = ""
        theUfSession.UF.TranslateVariable("USERNAME", strUserName)
        ' Get current date and time
        Dim CurDateTime As NXOpen.UF.SystemInfo
        theUfSession.UF.AskSystemInfo(CurDateTime)
        ' Get current Sheet
        Dim tagSheet As Tag
        theUfSession.Draw.AskCurrentDrawing(tagSheet)
        ' Get sheet dimensions
        Dim dwgSheet As Drawings.DrawingSheet = displayPart.DrawingSheets().CurrentDrawingSheet
        Dim dblSheetHeight As Double = dwgSheet.Height
        Dim dblSheetLength As Double = dwgSheet.Length
        Dim dblDistanceFromRight As Double
        Dim dblUserOriginX As Double
        Dim dblUserOriginY As Double
        ' Compute X Coordinates
        If dblSheetLength > 1189 Then
            dblDistanceFromRight = 330
            dblUserOriginX = 101
        Else
            dblDistanceFromRight = 230
            dblUserOriginX = 1
        End If
        ' Compute user Y coordinate
        If dblSheetLength > 1 Then
            dblUserOriginY = 1
        Else
            dblUserOriginY = 0
        End If
        ' Calculate user note location
        Dim dblCheckPlotXOrigin As Double = (dblSheetLength - dblDistanceFromRight)
        ' Calculate user coordinates
        Dim userX As Double = (dblSheetLength - dblUserOriginX)
        Dim userY As Double = (dblSheetHeight - dblUserOriginY)
        ' Add the check plot notes
        Dim strCHKPlot As String = "CHECK PLOT - DO NOT USE TO SOURCE OR MANUFACTURE"
        Dim strUser As String = CurDateTime.date_buf & " " & strUserName.ToUpper
        Dim checkPlotNote As Annotations.Note = PlotBanner(dblCheckPlotXOrigin, 12.5, strCHKPlot, 7, 90)
        Dim userPlotNote As Annotations.Note = PlotBanner(userX, userY, strUser, 3.5, 0)
        Dim dbl11inScale As Double = 270 / dblSheetHeight
        Dim dblPlotScale() As Double = {1, 0.5, dbl11inScale}
        ' Plot the Sheet
        UFPlotSheet(tagSheet, dblPlotScale(blkPaper.SelectedIndex), strPlotter)
        ' Delete check plot note
        Dim DelMark As Session.UndoMarkId = theSession.SetUndoMark(Session.MarkVisibility.Visible, "Delete Notes")
        Dim Note1 As NXObject = CType(checkPlotNote, NXObject)
        Dim Note2 As NXObject = CType(userPlotNote, NXObject)
        theSession.UpdateManager.AddToDeleteList(Note1)
        theSession.UpdateManager.AddToDeleteList(Note2)
        theSession.UpdateManager.DoUpdate(DelMark)
    End Sub
    Public Sub UFPlotSheet(ByVal sheet As Tag, plotscale As Double, strSelPlotter As String)
        ' Set Plot Job Variables
        Dim myJobOptions As UFPlot.JobOptions
        theUfSession.Plot.AskDefaultJobOptions(myJobOptions)
        myJobOptions.colors = UFPlot.Colors.BlackOnWhite
        myJobOptions.use_drawing_sheet_widths = False
        myJobOptions.widths = UFPlot.Widths.Custom3Widths
        Dim jobName As String
        theUfSession.Plot.AskDefaultJobName(sheet, jobName)
        Dim jobUnits As UFPlot.Units = UFPlot.Units.Millimeters
        Dim jobOrigin() As Double = {0, 0, 0}
        Dim jobBannerOptions As UFPlot.BannerOptions
        theUfSession.Plot.AskDefaultBannerOptions(jobBannerOptions)
        ' Remove defaulted on banner text
        jobBannerOptions.show_banner = False
        ' Find the default custom pen widths
        Dim jobDefaultWidths As UFCgm.CustomWidths
        theUfSession.Plot.AskSessionCustomWidths(jobDefaultWidths)
        jobDefaultWidths.use = UFCgm.WidthUse.WidthByWidth
        jobDefaultWidths.units = UFConstants.UF_PART_METRIC
        ' Variable to hold new custom pen widths
        Dim CustomWidths() As UFCgm.WidthCustom = jobDefaultWidths.custom
        Dim intNumberOfWidths As Integer = CustomWidths.Length
        For i = 0 To intNumberOfWidths - 1
            CustomWidths(i).Width = CustomWidths(i).Width * plotscale
        Next
        jobDefaultWidths.custom = CustomWidths
        ' Actually set Pen widths!!!
        theUfSession.Plot.SetSessionCustomWidths(jobDefaultWidths)
        Dim jobExtents As UFPlot.Extents
        ' Add layout to Plot
        theUfSession.Plot.AddJobToPlotLayout(sheet, myJobOptions, jobName, jobUnits, jobOrigin, UFPlot.Rotation.Rotation0, plotscale, jobExtents)
        ' Plot
        theUfSession.Plot.PrintPlotLayout(jobName, jobBannerOptions, strSelPlotter, "<System Profile>", 1)
        ' Set widths back to default
        Dim SetDefaultWidths As UFCgm.CustomWidths
        theUfSession.Plot.AskDefaultCustomWidths(SetDefaultWidths)
        SetDefaultWidths.use = UFCgm.WidthUse.WidthByWidth
        SetDefaultWidths.units = UFConstants.UF_PART_METRIC
        Dim DefaultWidths() As UFCgm.WidthCustom = SetDefaultWidths.custom
        SetDefaultWidths.custom = DefaultWidths
        ' Actually set pen widths!!!
        theUfSession.Plot.SetSessionCustomWidths(SetDefaultWidths)
    End Sub
    Public Function PlotBanner(ByVal userX As Double, _
                    ByVal userY As Double, _
                    ByVal BannerText As String, _
                    ByVal fontheight As Double, _
                    ByVal bannerangle As Double) As Annotations.Note
        Dim nullAnnotations_SimpleDraftingAid As Annotations.SimpleDraftingAid = Nothing
        Dim UserNoteBuilder1 As Annotations.DraftingNoteBuilder
        UserNoteBuilder1 = displayPart.Annotations.CreateDraftingNoteBuilder(nullAnnotations_SimpleDraftingAid)
        UserNoteBuilder1.Origin.Plane.PlaneMethod = Annotations.PlaneBuilder.PlaneMethodType.XyPlane
        UserNoteBuilder1.Origin.SetInferRelativeToGeometry(True)
        If fontheight = 7 Then
            UserNoteBuilder1.Origin.Anchor = Annotations.OriginBuilder.AlignmentPosition.BottomLeft
            Dim fontIndex2 As Integer
            fontIndex2 = displayPart.Fonts.AddFont("lubalins")
            UserNoteBuilder1.Style.LetteringStyle.GeneralTextFont = fontIndex2
        Else
            UserNoteBuilder1.Origin.Anchor = Annotations.OriginBuilder.AlignmentPosition.TopRight
        End If
        Dim nullView As View = Nothing
        Dim notepoint As Point3d = New Point3d(userX, userY, 0.0)
        UserNoteBuilder1.Origin.Origin.SetValue(Nothing, nullView, notepoint)
        UserNoteBuilder1.Style.LetteringStyle.Angle = bannerangle
        UserNoteBuilder1.Style.LetteringStyle.GeneralTextSize = fontheight
        Dim text1(0) As String
        text1(0) = BannerText
        UserNoteBuilder1.Text.TextBlock.SetText(text1)
        Dim BannerObject As Annotations.Note
        BannerObject = UserNoteBuilder1.Commit()
        UserNoteBuilder1.Destroy()
        Return BannerObject
    End Function
    Public Function GetUnloadOption(ByVal dummy As String) As Integer
        Return Session.LibraryUnloadOption.Immediately
    End Function
End Class
