Save Manager gift
Dear All,
A small gift to you.
I attached my Save Manager application.
I am not a developer but I hope you can use it.
You can choose from three actions from the Operation group.
Rename.pngRenameSave All.pngSave All
You can use the Shortcut menu to set the actions.
Selection_Shortcut_menu.pngShortcut
You can select "No Action" to the rows.
No_Action.pngNo Action
You can add prefix/suffix string or replace the string.
Prefix_Suffix.pngPrefix/Suffix/Replace
You can use the Save As action on the row.
Save_As.pngSave As
You can use the Replace Component on the row.
Replace.pngReplace Component
In both cases you have to use the Submit button to check the files.
Confirm_Changes.pngConfirm
 PS: Set path of the ugraf.exe and the path of the UGII_USER_DIR in the start.bat file.
Attila Szepesi, Application Engineer, graphIT Ltd.
Production: NX12.0.2 NX1863 | TcUA 11.3
Development: VB.NET, C# Testing: NX--
25 REPLIES 25
Re: Save Manager gift
I added a new version.
if I want to save an assembly I get the message
"The Part is not an Assembly!"
NX version 12.0
Save Manager version NXPPACK_SAVE_v1.0
Is a name definition required for the assembly?
Hi @aszepesi,
I've the same error like @ChristianS.
Thank you...
Using NX1867
RuleDesigner PDM
Sorry All,
Try this
Hello aszepesi,
Thanks for the update.
It's working!
thank you
Merry Christmas and a Happy New Year
 ...Christian
Hi @aszepesi,
thank you for the corrections.
Now it's all right.
Thank you...
Using NX1867
RuleDesigner PDM
Hi aszepesi
Im trying to save and get this error when clic in save manager.
Can yo help me?
Thank you.
Francisco Viti
@AMasriera wrote:
Hi aszepesi
Can yo help me?
Thank you.
Francisco Viti
after install the last MP, I've the same error.
Thank you...
Using NX1867
RuleDesigner PDM
Dear All,
I solved.
