Re: Save Manager gift
Hi @aszepesi,
form me works fine now.
Thank you...
Using NX1867
RuleDesigner PDM
Is the tool working also for Simulation files like .sim, .fem, .asm etc...?
Thank you
No, it doesn't work with sim, fem files. Maybe in future
Attila Szepesi, Application Engineer, graphIT Ltd.
Production: NX12.0.2 NX1863 | TcUA 11.3
Development: VB.NET, C# Testing: NX--
Hi @aszepesi ,
sorry to start using your program only now, but it's time to use it because we have received an assembly from China and we have to replace all strange file name with our company syntax. Which procedure do you suggest me to recode all parts to remove China characters ?
Why I don't see the icons in the structure ?
The program works, but the version 3.0 doesn't show icons.
Thank you...
Using NX1867
RuleDesigner PDM
Hi @cubalibre00 ,
Are there any files in the "icons" folder?save_manager_icons.pngSave Manager Icons
Hi @aszepesi ,
thank you for your rapid support. Apart renaming the ribbon tab and the command, the structure folder is like your.
Thank you...
Using NX1867
RuleDesigner PDM
Hi @cubalibre00 ,
Your folder structure is different. I don't know your customization. I try to copy the NXSaveManager icon files into the "Tooolbars\Bitmaps" folder.
Hi @aszepesi ,
your dll code, where search icons folder?
The folder structure is different but the program works, then it's configured well. Maybe your code is not smart on searching icons.
Thank you...
Using NX1867
RuleDesigner PDM
Hi @cubalibre00 ,
The code contains this row: theUFSession.UF.TranslateVariable("UGII_USER_DIR", icon_path), so the NXSaveManager icons folder must be in the "UGII_USER_DIR" folder.
Hi @aszepesi ,
resolved with your pieces of information. Thank you.
Thank you...
Using NX1867
RuleDesigner PDM
