Save a value in the NX session
I want to change the work layer before entering the dimension function to layer 22 so that all dimensions are created on layer 22. For that I use the menuscript: ACTIONS/PRE set-worklayer-22.dll. In this dll I want to save the actual work layer in the NX session for a reset function I want to call with the post action of the dimension function.
My first idea is to use an environment variable and use the SetEnvironmentVariableValue and GetEnvironmentVariableValue functions. Does anyone know a better way?
Stefan
Mit freundlichen Grüßen / With kind regards
i.A. Dipl.-Ing. (FH) Stefan Walder
CAD Management
stefan.walder@gira.de
Tel +49(0)2195-602-319, Fax +49(0)2195-91603-319
Gira Giersiepen GmbH & Co. KG, Elektro-Installations-Systeme
Industriegebiet Mermbach, Dahlienstraße, 42477 Radevormwald, Deutschland
Intelligente Gebäudetechnik von Gira. www.gira.de
Handelsregister AG Köln HRA 16352
Persönlich haftende Gesellschafterin: GAV Management GmbH,
Handelsregister AG Köln HRB 50479
Geschäftsführer: Dipl.-Kfm. Dirk Giersiepen, Alfred A. Bulitz,
Dipl.-Kfm. Thomas Musial
Gira Giersiepen GmbH & Co. KG, Electrical installation systems
Industriegebiet Mermbach, Dahlienstraße, 42477 Radevormwald, Germany
Intelligent building technology by Gira. www.gira.com
Register of Business Names: AG Köln HRA 16352
Partner Personally Responsible: GAV Management GmbH,
Register of Business Names: AG Köln HRB 50479
Managing Directors: Dipl.-Kfm. Dirk Giersiepen,
Dipl.-Wirtschafts-Ing. (FH) Oliver Borchmann, Alfred A. Bulitz,
Re: Save a value in the NX session
Why not set an attribute with the previous layer? Just in case you have two NX sessions running and you start dimensioning.With an attribute you will be certain that you can jump back to a layer that was used before.
W10 NX12.0.1.7
I
don't want to use a part attribute because I don't want to take affort in deleting the attribute when I don't need it anymore.
I want to use a place in the session context to save information for later user in an other dll.
The environment variable works but I'm not sure if there is a better way to do it.
Stefan
CAD Management
What would be a better way?
Using the environment variable you would not know if the current layer is the previous one, if your dialog crashes, if you don't clear it afterwards either.
Both ways are working in a similar way and both exhibit the problem of how to determine if the layer must be saved or not, when run after the dialog crashed.
Some other alternatives would be to write the info to a file in the user's temporary folder or write the info to the registry. I'm not sure that either of those options would be "better" than what you are doing now, though.
If you are in a part file, could you use an expression - previous_layer=22 ?
Mark Rief
Retired Siemens
The problem with external files is that they can get deleted.
We do have a policy to clear the temporary folder when the user logs off, for example.
Best way to keep information between sessions is to use attributes, they are easy to create and check.
