Select a vertex
Innovator
Innovator
How do you select a vertex/ endpoint of a line or curve?
Re: Select a vertex
Honored Contributor
Honored Contributor
One approach (there are others) is to use the PointSubfunction. You can find a code example in the following thread:
http://community.plm.automation.siemens.com/t5/NX-Programming-Customization/BlockStyler-Selection-fi...
