Select view in Block Styler
Hello everyone!
How can I build a Select view button in Block Styler, similart to the OOTB NX one? It is not present in Block Styler, so I guess I need to take some more general type and modify it? Could you please explain?
Re: Select view in Block Styler
Any ideas?..
Have you tried using a simple selection block and set the filter on it to only allow views? I've not tried this, but you should be able to do the following (pseudo-code):
MaskTriple mt[] = new MaskTriple[1]
mt[0].Type = UFConstants.UFConstants.UF_view_type
mt[0].Subtype = 0
mt[0].SolidBodySubtype = 0
PropertyList pl=SelectionBlock.getProperties()
pl.SetSelectionFilter("SelectionFilter", SelectionAction.CLEAR_AND_ENABLE_SPECIFIC, mt)
To make the block look nice you could also set the image:
pl.SetBitmap("view_select")
Production: [NX8.5.3.3 MP11 64bit] Testing: [NX12.0.0.27 MP1]
Haven't tried it yet, but I was slowly working my way toward the same solution. Sorted out the bitmaps question, for example. Man Happy What selection block shall I use? "Select Object"?
Yes, SelectObject is the general use one that you should be able to modify to look/work like the native selection blocks that are not directly covered by BlockStyler.
Thank you! I'll get busy now.
Just one question - is it possible to hide number of selected symbols in the name string? It is a bit misleading when only a single selection is required.
Hmm.. I've never really thought about that. But as far as I can tell, I don't think so.
You'd think if the selection mode was single, it would automatcially be omitted.
That was my impression as well.
