Selectionfilter for FE Element Edge
Hi all,
I am trying to configure a Selection::MaskTriple for the selection of FE Element edges in NX10, using C++.
I already found the selection filter types for:
UF_pseudo_CAE_subtype   (1)
UF_pseudo_CAE_node      (1)
UF_pseudo_CAE_element   (2)
and used it as follows:
vector<Selection::MaskTriple> selection_Mask_Array(1);
Selection::MaskTriple selection_Mask;
selection_Mask.Type = UF_pseudo_object_type;
selection_Mask.Subtype = UF_pseudo_CAE_subtype;
selection_Mask.SolidBodySubtype = UF_pseudo_CAE_element;
selection_Mask_Array[0] = selection_Mask;
For a new routine, I need my users to select an element edge, unnfortunately in "uf_ui_types.h" there is nothing like "CAE_element_edge".
I guess that it has to be possible, as there is a Selectionfilter in NX UI, when you use the smart selection manager's "Feature Edge Nodes"-method:screenshot.jpg
Hopefully someone knows what's to specify in the MaskTriple in code.
Best regards,
Re: Selectionfilter for FE Element Edge
NX 10 only contains subtypes for nodes and elements. Subtypes for element edges and faces were added in NX 11:
#define UF_pseudo_CAE_subtype   (1)
#define UF_pseudo_CAE_node      (1) /* first CAE detail type */
#define UF_pseudo_CAE_element   (2) /* second CAE detail type */
#define UF_pseudo_CAE_elemface  (3) /* third CAE detail type */
#define UF_pseudo_CAE_elemedge  (4) /* fourth CAE detail type */
