Do you mean
Reply
Set masktriple for ordinate origin
Hello, can any body tell me how to set the filter to select ordinate origin in a drafting view and to be exactly like the filter of the ordinate origin of NX hole table?? thanks in advance
Re: Set masktriple for ordinate origin
I think you would set your mask triple to UFConstants.UF_dimension_type, UFConstants.UF_dim_ordinate_origin_subtype, 0
Disclaimer:  I have not tried this.
well, i don't get the exact behaviour as some desired points cannot be selected and other undesired points can be selected.
but anyway thanks for your help.
I don't know about ordinate origins, but it could be a so called feature and you should use a SelectFeature-Block.
Anyway you might want to try messing with Block.AddFilterHandler and the callback.
