Siemens NX Launcher Availability
the NX 1872 documentation states that the Siemens NX Launcher is available from GTAC or from the install media.
Can you please assist in locating the tool in GTAC and in the install media?
3 REPLIES 3
Re: Siemens NX Launcher Availability
Hi @Sebastian5050 ,
in GTAC is not present.
The media is not any more sent to the user, only download the full installation.
When you start the NX installation you have the button 'NX Launcher'.
Thank you..
Using NX1880 and RuleDesigner PDM
Built-in functions for converting units of measure
Have not noticed the new button, Thank you!
Hi @Sebastian5050 ,
have you tried the Siemens NX Launcher ?
I tried, but I discovered via GTAC that I need to install NX that I want to test as normal install.
https://community.plm.automation.siemens.com/t5/NX-Programming-Customization-Forum/Siemens-NX-Launch...
Thank you..
