Size of CustomSymbol
Hello together,
I am trying to get a customSymbol's width and Height, also its location like shown in the
ListingWindows (Information) when you navigate to CustomSysmbol->Properites->General and press the Information-button.
Is it possible ?
Thanks in advance,
Mark
Re: Size of CustomSymbol
Have you search uganswer (https://solutions.industrysoftware.automation.siemens.com/)?
Have you tried recording a journal (in your language of choice) where you edit a custom symbol's size?
Yes I have Unfortunately nothing yielded in usable results so far.
For those who are interested:
I opened an IR at GTAC and the reply was that ist is not possible to retrieve the size/width of an customsymbol yet. However the MAsterSymbol's path can be obtained by the following example code
Dim wp As Part = theSession.Parts.Work
        Dim it As IEnumerator = wp.Annotations.CustomSymbols.GetEnumerator()
        it.Reset()
        While it.MoveNext
                Dim csb As DraftingCustomSymbolBuilder = wp.Annotations.CustomSymbols.CreateDraftingCustomSymbolBuilder(it.Current)
                Debug.WriteLine(csb.MasterSymbolPath)
                it.MoveNext()
        End While
