Timestamp on linked body
Innovator
Innovator
Is there any way to programatically turn the "Fix at Current Timestamp" checkbox off in the Wave Geomerty Linker Dialog box that pops up when you double click a Linked Body Feature?
Re: Timestamp on linked body
Honored Contributor
Honored Contributor
You have existing "linked body" features that you want to modify to turn off the "at timestamp" option?
If so, create a "WaveLinkBuilder" object to edit the linked feature and use the builder's .FixAtCurrentTimestamp property to set the linked feature's option as desired.
