cancel
Translate an NX Assembly to Step
Hi, We are trying to translate an NX Assembly to Step. If a component of the assembly is saved with a different reference set than "Entire Part" or if the component has an arrangement, then in the Step Translation we get the name of the component as the original name + the reference set name or the arrangement name. We would like to get the original names without the reference set name or the arrangement name. How can we do it? Thanks a lot, Idit Gvirtz
