Tree list get node
Is there a way to get a node from a tree list, based on the displayed text?
So the goal is to enter a string and getting the node which has the same displayed text as the entered string.
Thanks in advance.
Laurens
Re: Tree list get node
I think it is quite easy.  Iterate through the TreeList.  For each Node get the DisplayText property and compare it to the required string.
There is an example program on the Solution Center that uses GetColumnDisplayText property.
https://solutions.industrysoftware.automation.siemens.com/view.php?sort=desc&dt=nx-api&file_type=tex...
Suresh
Production: NX10.0.3 Developing: NX11.0.2.7, NX12.0.1
Development: C++, C# .Net, VB .Net, KF
Thank you!
Got it to work thanks to you!
