UF_ASSEM_ask_part_occ_children() assembly order
UF_ASSEM_ask_part_occ_children() at times returns children in the assembly tree order (chronlological), but at other times it does not (one case I've noticed specifically after using Create New Parent).
I've seen many issues regarding this going back years.  Does anyone know if a consistent method is now available?
Re: UF_ASSEM_ask_part_occ_children() assembly order
The .AskChildrenOrder method may get what you need.
