cancel
UF_KF_ask_tag returns 0 when given a hostpointer of an expression
Innovator
Innovator
Hello everyone,
I am currently working on a method to retrieve an NX tag of a KF list element. The KF list contains an element of type HostPointer, and this references an expression in the same part as the KF instance containing the said list. From what I can gather from the hostpointer, the expression exists in the part.
However, if I create a KF attribute with the contents "%mqc_asktagofhostpointer(...)", it returns 0 (NULL_TAG). This can be reproducible using UF_KF_ask_tag.
Has anyone also come across this issue? Is there a workaround?
Any help would be much appreciated. Thanks!
Marc Prosl
NX Software Developer
