UI.Block buttons clicked unwantedly
I have a problem with a two dialog vb.net SNAP program in compiled mode using UI.Blocks. (NX 12.0.2)
I have two dialogs: dialog A and dialog B.
I have 4 buttons on dialog A which one of them opens dialog B.
When I go to dialog B and finish my job by clicking OK I come back to dialog A but all other buttons on dialog A are clicked unwantedly!!
I have handled all button clicks by onUpdate function and checking the changed block inside onUpdate.
I don't know what to do about it.
Do you have any Idea?
Regards.
13 REPLIES 13
Re: UI.Block buttons clicked unwantedly
Can you post the onUpdate() method code of dialog A...
Dell 7530 Precision, Win10, 32GB. Developing in: Java | C | KF
Production: [NX12.0.2 MP1]
Hi @Inch
this is the OnUpdate sub in dialog A class:
    Public Overrides Sub OnUpdate(changedBlock As UI.Block.General)
        If changedBlock = constraintsButton Then
            ' Create and display a define_constraints_form dialog (dialog B)
            Dim define_constraints_form = New Define_Constraints()
            define_constraints_form.Show()
        End If
        If changedBlock = autoButton Then
            MsgBox("autoButton clicked")
        End If
        If changedBlock = colorButton Then
            MsgBox("colorButton clicked")
        End If
        If changedBlock = manualButton Then
            MsgBox("manualButton clicked")
        End If
    End Sub
Actually I am just developing the dialogs structure now and the main program code is not added yet.
Regards.
The Radio Box is an Enumeration.  So the dilaog ID (in your case changedBlock) will be same.  In your OnUpdate callback all the if statements will be true.  You need to check for the checked item value.
Suresh
Technisites Australia
Production: NX10.0.3 Developing: NX11.0.2.7, NX12.0.2, NX1847,
Development: C++, C# .Net, VB .Net, Python, KF
@robot139are you using a Radio Box? This could be the problem.
Maybe you could post the DLX file too.
I don't see a Radio Box nor the need for a DLX file when using Snap.UI.BlockForm dialogs.
But without seeing the whole code and exact steps, others can only make assumptions here and I could not see this problem with the following codes either.
MyDialogA.vb
Option Infer On
Imports Snap, Snap.Create
Public Class MyDialogA : Inherits Snap.UI.BlockForm
    Dim constraintsButton As UI.Block.Button
    Dim autoButton As UI.Block.Button
    Dim colorButton As UI.Block.Button
    Dim manualButton As UI.Block.Button
    Public Sub New()
        Me.Title = "MyDialogA"
        constraintsButton = New UI.Block.Button("Constraints")
        autoButton = New UI.Block.Button("Auto")
        colorButton = New UI.Block.Button("Color")
        manualButton = New UI.Block.Button("Manual")
        Me.AddBlocks(constraintsButton, autoButton, colorButton, manualButton)
    End Sub
    Public Shared Sub Main()
        Dim myFormA = New MyDialogA()
        myFormA.Show()
    End Sub
            Dim myFormB = New MyDialogB()
            myFormB.Show()
        End If
        End If
        End If
        End If
    End Sub
    Public Shared Function GetUnloadOption(ByVal dummy As String) As Integer
        Dim unloadOption As Integer
        unloadOption = Snap.UnloadOption.Immediately       ' After executing
        Return unloadOption
    End Function
End Class
MyDialogB.vb
Option Infer On
Public Class MyDialogB : Inherits Snap.UI.BlockForm
    Dim integerBlock As UI.Block.Integer
    Public Sub New()
        Me.Title = "MyDialogB"
        integerBlock = New UI.Block.Integer("Enter number")
        Me.AddBlocks(integerBlock)
    End Sub
        If changedBlock = integerBlock Then
            InfoWindow.WriteLine("You entered " & integerBlock.Value.ToString())
        End If
    End Sub
End Class
Hi experts
Thanks for your time.
I have no DLX and I have an enumeration on dialog B.
Here is my complete code:
Option Infer On
Imports Snap, Snap.Create, Snap.NX.ObjectTypes
Public Class dialog_A : Inherits UI.BlockForm
    ' Declarations of the blocks on a dialog_A dialog
    Dim pointSelector As UI.Block.SelectObject
    Dim curveSelector As UI.Block.SelectObject
    Dim button_A1, button_A3, button_A2, button_A4 As UI.Block.Button
    Dim sep As UI.Block.Separator
    Public Sub New()
        Me.Title = "Dialog A"
        Me.Cue = "Please enter information"
        ' Create a point selection block
        pointSelector = New UI.Block.SelectObject("select points", "Select Points")
        pointSelector.BeginGroup = True
        pointSelector.SetFilter(Type.Point)
        pointSelector.AllowMultiple = True
        '-- Create first curve selection block
        curveSelector = New UI.Block.SelectObject("select lines or arcs", "Select Curves")
        curveSelector.BeginGroup = True
        curveSelector.SetFilter(Type.Arc, Type.Line)
        curveSelector.AllowMultiple = True
        ' Create button
        button_A1 = New UI.Block.Button("button_A1")
        ' Create button
        button_A2 = New UI.Block.Button("button_A2")
        ' Create button
        button_A3 = New UI.Block.Button("button_A3")
        ' Create button
        button_A4 = New UI.Block.Button("button_A4")
        sep = New UI.Block.Separator()
        ' Add the blocks to the BlockForm
        Me.AddBlocks(pointSelector, curveSelector, button_A1, button_A2, button_A3, button_A4)
    End Sub
        ' Create and display dialog_A
        Dim myForm = New dialog_A()
        myForm.Show()
    End Sub
    Public Overrides Sub OnShow()
        ' Code for when dialog is displayed
    End Sub
    Public Overrides Sub OnOK()
        ' Code for when user clicks OK
    End Sub
    Public Overrides Sub OnApply()
        ' Code for when user clicks Apply
    End Sub
    Public Overrides Sub OnCancel()
        ' Code for when user clicks Cancel
    End Sub
        If changedBlock = button_A1 Then
            ' Create and display a dialog_B dialog
            Dim dialog_B = New dialog_B()
            dialog_B.Show()
        End If
        If changedBlock = button_A2 Then
            MsgBox("button_A2 clicked")
        End If
        If changedBlock = button_A3 Then
            MsgBox("button_A3 clicked")
        End If
        If changedBlock = button_A4 Then
            MsgBox("button_A4 clicked")
        End If
    End Sub
End Class
Option Infer On
Public Class dialog_B : Inherits UI.BlockForm
    Dim testButton As UI.Block.Button
    Dim curveSelector1, curveSelector2 As UI.Block.SelectObject
    Dim menuBlock As UI.Block.Enumeration
    Dim button_B1, button_B2 As UI.Block.Button
    Public Sub New()
        Me.Title = "Dialog B"
        ' Create an option menu block
        menuBlock = New UI.Block.Enumeration()
        menuBlock.BeginGroup = True
        menuBlock.Label = "type"
        menuBlock.Items = {"type 1", "type 2", "type 3", "type 4"}
        menuBlock.PresentationStyle = UI.Block.EnumPresentationStyle.OptionMenu
        menuBlock.Layout = UI.Block.Layout.Horizontal
        curveSelector1 = New UI.Block.SelectObject("select line or arc", "Select First Curve")
        curveSelector1.BeginGroup = True
        curveSelector1.SetFilter(Type.Arc, Type.Line)
        curveSelector1.AllowMultiple = False
        '-- Create second curve selection block
        curveSelector2 = New UI.Block.SelectObject("select line or arc", "Select Second Curve")
        curveSelector2.BeginGroup = True
        curveSelector2.SetFilter(Type.Arc, Type.Line)
        curveSelector2.AllowMultiple = False
        ' Create button
        button_B1 = New UI.Block.Button("button_B1")
        ' Create button
        button_B2 = New UI.Block.Button("button_B2")
        Me.AddBlocks(menuBlock, curveSelector1, curveSelector2, button_B1, button_B2)
    End Sub
    'Public Shared Sub Main()
    'End Sub
    End Sub
        If changedBlock = button_B1 Then
            Dim curves1 = curveSelector1.SelectedObjects
            Dim curves2 = curveSelector2.SelectedObjects
            MsgBox("button_B1 clicked")
        End If
        If changedBlock = button_B2 Then
            MsgBox("button_B2 clicked")
        End If
    End Sub
End Class
Public Class Unload
        'unloadOption = Snap.UnloadOption.AtTermination     ' When NX session terminates
        'unloadOption = Snap.UnloadOption.Explicitly        ' Using File-->Unload
        Return unloadOption
    End Function
End Class
And this little video shows my problem:
(view in My Videos)
As you see in the video when I click OK on dialog B and come back to dialog A all of the buttons on dialog A are clicked one by one.
Any help is apreciated.
Thanks.
Hi everyone
I found a workaround by trial and error.
In my OnUpdate sub instead of
I used:
If changedBlock.NXOpenBlock.Tag = button_A1.NXOpenBlock.Tag Then
Yes, I was now also able to see this wrong behavior in NX12.0.2 and once I hit this issue then the second dialog was even shown when clicking ANY of the first dialog.
But it works fine for me in NX1847 so I believe it had been fixed already and your workaround for NX12.0.2 by comparing the Tag seems to do the trick, as well.
I think I know what the problem is now.
We found that in NX12 if you have two block dialogs and open the second block dialog from the first, when you return to the first dialog all of the blocks have lost their names (i.e. calling myButton.name() returns "").
I'm guessing that when you compare blocks in SNAP, internally it is comparing the names of the blocks using block.name(). When all the blocks return "" as their name they all match each other!
I opened an IR that got converted to PR9108453  on this issue. This is stated as fixed in NX1847, but I haven't got that installed yet to try it out.
We don't use SNAP, so we have separate DLX files, but I guess the same problem would affect SNAP too as it is only a wrapper around VB. @Yamada would be able to confirm this.
