UI Builder: List box side by side?
To all
Is there a way of having 2 list boxes side-by-side rather than 1 below the other (default)?
I looking at the possibility of having a UI in a "2 columns" format
column 1              column 2
1 list box                1 list box
and below             and below
5-off toggles          5-off toggles
is this possible?
Thansk
Production: NX.CAE 9.0.3.4, NX.CAE 10.0.2.6
Re: UI Builder: List box side by side?
I think you must create a separate group to be able to specify the columnar display different from the one in the entire dialog.
Thanks for the tip. Looks like setting property column = 2 in the default group does the trick. See attached test with only 1 group.
you can do it with the attachments of each list box
