Unsafe to build a bottom dialog.
string currapp = theSession.ApplicationName;
if (currapp != "UG_APP_GATEWAY")
      theSession.ApplicationSwitchImmediate("UG_APP_GATEWAY");
//Launch the dialogue
After changing the application unable to launch the styler dialogue. Getting following error message
APP_ENTERED_APPLICATION_ENVIRONMENT_CALLBACK_ID UG_APP_GATEWAY.
*** EXCEPTION: Error code 1560012 in line 1004 of o:\ugnx1101\ip11\src\ugui\styler\ind\bld_uf.c at Mon Apr 24 18:40:33 2017 India Standard Time
+++ Unsafe to build a bottom dialog.
Please help me on this
Thanks & Regards
Balakrishnan M
Re: Unsafe to build a bottom dialog.
This was recently reported to GTAC and referred to development for resolution as a Problem Report:
Problem Description:  After calling ApplicationSwitchImmediate, trying to launch a Pre-NX6 UI Styler dialog (.dlg) within the same program will fail with Error code  1560012 ...  +++ Unsafe to build a bottom dialog.
The failure does not occur with a Block UI Styler (.dlx) dialog.
It is reported to be fixed in NX11.0.2.
Thanks for the  response. Please share the PR/ER No.
Balakrishnan M
The PR is 7920674.
