Updating the Manufacturing View
HI Guys.
How do you update the Manufacturing ONT in NX12 or higher using the api?
In previous versions swapping from Mafuacturing to Modelling and back to Manufacturing used to refreash the ONT, it doesn't anymore?!
MAnt thanks in advance
Re: Updating the Manufacturing View
Perhaps UF_UI_ONT_refresh() can be worth a try in this case.
That was enough to point me in the right direction.
theUFSession.UiOnt.Refresh()
did the trick..
Cheers
