(VB .Net) Call another Block Styler within a button
Hi all
I made a block styler with a button and a string. How can I call another block styler and return the data which I want input to the string?
Best Regard
Christian
Best Regards
Christian
Re: (VB .Net) Call another Block Styler within a button
Is this function can not be achieved?
Best Regards
Christian
It is possible.  Look at the following example on the solution center.
https://solutions.industrysoftware.automation.siemens.com/view.php?sort=desc&q=blockstyler+callback&...
or search for "post second block styler dialog from an action button of another"
Suresh
It works perfectly ! Thanks a lot !
Best Regards
Christian
