VLA Types
Hello all,
I have a newbie question:
I'm trying to get information on an operation via the UFSession.
I have a Switch Case section for each type of attribute's value.
Those are the possible types:
_TYPE_STRING
_TYPE_DOUBLE
_TYPE_DOUBLE_LENGTH
_TYPE_LOGICAL
_TYPE_INT
_TYPE_SHORT
_TYPE_CHAR
_TYPE_BYTE
_TYPE_DATE
_TYPE_FLOAT
_TYPE_LAST
_TYPE_OBJECT
_TYPE_POINTER
_TYPE_TAG
_TYPE_VLA_DOUBLE
_TYPE_VLA_INT
_TYPE_VLA_STRING
_TYPE_VLA_TAG
_TYPE_VLA_LENGTH
_TYPE_VLA_LENGTH_COMPOSITE
What does the VLA means?
P.S.
Also there are some attributes with an array of values. Does someone has an idea how to save this attribute on a table?
Tom.
Re: VLA Types
VLA = variable length array
Have never had the need to access VLA values, but the solution center might have an example of how to use them.
Re: VLA Types
Thanks.
There is any way to get the values of the type POINTER objects?
Re: VLA Types
What parameter is returning a pointer?
