View Orientation Fit NX Journal for Assemblies
I am new to NX 7.5 and I am writing a Journal to simply fit the part within the view and then set the view to isometric, and save. My only difficulty is applying this to a large assembly that has 100+ Components and sub Assemblies. Currently I have the view orient code below. How do I apply this to multiple parts/assemblies?
Option Strict Off
Imports System
Imports NXOpen
Module NXJournal
Sub Main
Dim workPart As Part = theSession.Parts.Work
Dim displayPart As Part = theSession.Parts.Display
workPart.ModelingViews.WorkView.Fit()
workPart.ModelingViews.WorkView.Orient(View.Canned.Isometric, View.ScaleAdjustment.Fit)
Dim partSaveStatus1 As PartSaveStatus
partSaveStatus1 = workPart.Save(BasePart.SaveComponents.True, BasePart.CloseAfterSave.False)
partSaveStatus1.Dispose()
End Sub
End Module
Re: View Orientation Fit NX Journal for Assemblies
Update:
I've compiled code that works for the top assembly and the 1st level parts.
Is there anyway to modify this to work on subassemblies as well?
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Imports NXOpen.Assemblies
Imports System.IO
Imports NXOpenUI
Imports System.Windows.Forms
Module NXJournal
Public theSession As Session = Session.GetSession()
Public ufs As UFSession = UFSession.GetUFSession()
Public lw As ListingWindow = theSession.ListingWindow
Sub Main()
Dim dispPart As Part = theSession.Parts.Display
'lw.Open
Try
Dim c As ComponentAssembly = dispPart.ComponentAssembly
'to process the work part rather than the display part,
' comment the previous line and uncomment the following line
'Dim c As ComponentAssembly = workPart.ComponentAssembly
if not IsNothing(c.RootComponent) then
'*** insert code to process 'root component' (assembly file)
'lw.WriteLine("Assembly: " & c.RootComponent.DisplayName)
'lw.WriteLine(" + Active Arrangement: " & c.ActiveArrangement.Name)
'*** end of code to process root component
'lw.WriteLine("")
'lw.WriteLine("comps")
'lw.WriteLine("")
dim comps() as component = c.RootComponent.getchildren()
Dim part2 As Part = CType(theSession.Parts.FindObject(c.RootComponent.DisplayName), Part)
for i as integer = 0 to ( comps.length - 1 )
'lw.writeline( comps(i).name )
Dim component1 As Assemblies.Component = comps(i)
Dim components1(0) As Assemblies.Component
components1(0) = component1
Dim errorList1 As ErrorList
errorList1 = component1.DisplayComponentsExact(components1)
errorList1.Clear()
Dim part1 As Part = CType(theSession.Parts.FindObject(comps(i).displayname), Part)
part1.Preferences.Modeling.CutViewUpdateDelayed = True
Dim partLoadStatus1 As PartLoadStatus
Dim status1 As PartCollection.SdpsStatus
status1 = theSession.Parts.SetDisplay(part1, True, False, partLoadStatus1)
workPart = theSession.Parts.Work
dispPart = theSession.Parts.Display
partLoadStatus1.Dispose()
'Dim part2 As Part = CType(theSession.Parts.FindObject(c.RootComponent.DisplayName), Part)
workPart.Preferences.Modeling.CutViewUpdateDelayed = True
Dim partLoadStatus2 As PartLoadStatus
Dim status2 As PartCollection.SdpsStatus
dispPart.ModelingViews.WorkView.Fit()
dispPart.ModelingViews.WorkView.Orient(NXOpen.View.Canned.Isometric, NXOpen.View.ScaleAdjustment.Fit)
dispPart.ModelingViews.WorkView.RenderingStyle = NXOpen.View.RenderingStyleType.Shaded
partSaveStatus1 = dispPart.Save(BasePart.SaveComponents.True, BasePart.CloseAfterSave.False)
status2 = theSession.Parts.SetDisplay(part2, True, False, partLoadStatus2)
partLoadStatus2.Dispose()
next
Dim partLoadStatus6 As PartLoadStatus
Dim status6 As PartCollection.SdpsStatus
Dim partSaveStatus2 As PartSaveStatus
status6 = theSession.Parts.SetDisplay(part2, True, False, partLoadStatus6)
Dim nullAssemblies_Component As Assemblies.Component = Nothing
dispPart.Preferences.Modeling.CutViewUpdateDelayed = True
Dim partLoadStatus7 As PartLoadStatus
theSession.Parts.SetWorkComponent(nullAssemblies_Component, PartCollection.RefsetOption.Current, PartCollection.WorkComponentOption.Visible, partLoadStatus7)
partSaveStatus2 = dispPart.Save(BasePart.SaveComponents.True, BasePart.CloseAfterSave.False)
partLoadStatus7.Dispose()
else
'*** insert code to process piece part
lw.WriteLine("Part has no components")
end if
Catch e As Exception
theSession.ListingWindow.WriteLine("Failed: " & e.ToString)
End Try
'lw.Close
End Sub
Public Function GetUnloadOption(ByVal dummy As String) As Integer
Return Session.LibraryUnloadOption.Immediately
End Function
End Module
(Thanks to Carlo Tony Daristotile)
http://www.nxjournaling.com/content/creating-subro...
JEHILL
The first block of code in the link you posted gives you what you need; it will process every component in an assembly. I'd suggest creating a subroutine that does what you want (given a part, orient the view and save it) and adding it to the journal in the link. Insert a call to your subroutine below the line:
'*** insert code to process component or subassembly
found in the "reportComponentChildren" subroutine.
cowski,
If I post the code as displayed it is only view orient and saving the top level assembly when ran in NX. This is inserting lines after the comment code.
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Module NXJournal
    Sub Main()
    lw.Open
    Try
            ReportComponentChildren(c.RootComponent, 0)
        else
        end if
    End Try
    lw.Close
    End Sub
    Sub reportComponentChildren( ByVal comp As Component, _
        ByVal indent As Integer)
        For Each child As Component In comp.GetChildren()
            lw.WriteLine(New String(" ", indent * 2) & child.DisplayName())
                dispPart.ModelingViews.WorkView.Orient(View.Canned.Isometric, View.ScaleAdjustment.Fit)
            '*** end of code to process component or subassembly
            if child.GetChildren.Length <> 0 then
                '*** this is a subassembly, add code specific to subassemblies
                   partSaveStatus2.Dispose()
                lw.WriteLine(New String(" ", indent * 2) & _
                    "* subassembly with " & _
                    child.GetChildren.Length & " components")
                    " + Active Arrangement: " & _
                    child.OwningPart.ComponentAssembly.ActiveArrangement.Name)
                                    '*** end of code to process subassembly
            else
                'this component has no children (it is a leaf node)
                'add any code specific to bottom level components
            end if
            reportComponentChildren(child, indent + 1)
        Next
    End Sub
    End Function
End Module
Let's take a look at what you have:
the variable dispPart is defined as whatever the current display part is.
For every component found, the following actions will be taken:
The current display part's view orientation changes and the display part is saved.
No where in the code does the display part ever get changed. What this means is the current display part (most likely the top level assembly at the time the journal is run) gets saved every time a component is found.
One way to fix this is to get the parent part file of the component geometry and make it the display part before performing those actions. The code below shows how to get the parent part from the component object.
Dim thePart as Part
thePart = child.prototype.owningpart
Try recording a journal while changing the display part to see what code would be needed to do that.
p.s. you will run into issues if the file cannot be found with your current search options or if the file is read-only. You might want to wrap the "change display" and "save" operations in a Try block to catch and handle errors.
I think I understand what your saying, but I am having trouble trying to set a displayed part with the FindObject(" ") function.
If I run the record it selects a specific file name with the FindObject ("xx-part name-xx")
What I really need is an identifier for that FindObject function that will open the current component found. Does this exist? what would be a work-around?
Thank you for the help.
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Module NXJournal
    Sub Main()
    lw.Open
    Try
        else
        end if
    End Try
    lw.Close
    End Sub
'** insert code to process component or subassembly
'***Sets Display part to the Component
               Dim part1 As Part = CType(theSession.Parts.FindObject("Part Number"), Part)
               status1 = theSession.Parts.SetDisplay(part1, True, True, partLoadStatus1)
'****Sets views to Display part
                Try
                End Try
'***Sets Display part to Root Component
               'Dim status1 As PartCollection.SdpsStatus
               status1 = theSession.Parts.SetDisplay(part2, True, True, partLoadStatus2)
'** end of code to process component or subassembly
'** this is a subassembly, add code specific to subassemblies
                   Try
                   End Try
'**** WriteLine
'** end of code to process subassembly
            else
            end if
        Next
    End Sub
    End Function
End Module
"What I really need is an identifier for that FindObject function that will open the current component found. Does this exist? what would be a work-around?"
Don't use the FindObject function. Given a reference to a component, you can get a reference to the part that owns the component geometry; I showed how to do that in my previous post.
Dim part1 as Part
part1 = child.prototype.owningpart
Where child is the reference to the current component in the reportComponentChildren subroutine.
