Volume change call back
Hi All,
I have a requirement, where in after i edit/add an any feature in my model tree, a call back should get called program should get called to to some face analysis. and automatically should show me the analysis result.
What i am thinking is, of course when the feature in the model tree is modified/ added. the volume of solid will changes, and this volume change should call a call back (?? thinking of it). in that call back we write the code to do face analysis.
Is there a way to handle above requirement.
Any suggesation will be greatly appreciated.
Arun
