Wavefront from NX conversion
I know that NX cannot export .obj or Wavefront|Alias files directly but I've seen on the SolidWorks boards that someone had written a converter to export .obj files directly from SW.
I won't post anyone else's code here but if you are interested in seeing the post, here it is: Wavefront Export
The scripts here seem to be written in Python & I'm not a Python person.
Thank you
