What is Nx ' Storage Manager'?
selex_ct 1st Gear
1st Gear
To all,
Attached is a snapshot on an error msg I occasionally get. It happens when I try to close a nx file (.sim)  and may or may not be related to me running some Nx customisation code (uncompiled.vb file)
Does anyone know what is this 'Storage Manager' mention in the message?
Re: What is Nx ' Storage Manager'?
cowski1 3rd Gear
3rd Gear
Are you calling the .Free method for anything? If so, try commenting those lines of code out to see if you get the same message.
selex_ct 1st Gear
1st Gear
No use of .Free (but then I don't knwo what it is!). I do have a few .Dispose
I don't really do memory management because my "programme" are very small and used occasionally.
As I doing some testing/developing and the test code crashes I might be "storing" things
Stefan_Pendl 3rd Gear
3rd Gear
There is no need to manage memory, since this is done by the storage manager automatically.
You might dispose an object too early, so check for that.
Production: NX10.0.3, VERICUT 8.1, FBM, MRL 3.1.4 | TcUA 10.1 MP7 Patch 0 (10.1.7.0) | TcVis 10.1
Development: VB.NET, Tcl/Tk Testing: NX12.0 Preparing: NX12.0
Siemens Creator
I think the storage manager is the "tool" managing memory as you are running NX, including your custom code.
One thing will help -- check the SYSLOG file after this occurs.  THere should be a "call stack" of information of where the error occurred.  This might help you determine something more about the error.
Dave Figurski
GSS / Siemens Industry Sector
selex_ct 1st Gear
1st Gear
Thanks for that. Having look at the syslog this is what I found just before the error msg: 1. a few line of "Severe error 904 ..." 2. the error message and just after 3. ***ERROR: application UG_APP_SFEM unexpectedly returned to Gateway Unloading C:\Program Files\Siemens\NX 9.0\ugstructures\nastran.dll
selex_ct 1st Gear
1st Gear
I'll blame the issue on my limited programming skills at the moment
Siemens Creator
Can you attach all the LINES OF THE ERROR from the syslog information?
Were there any lines in there that identified lines in your code?
one thought -- maybe you DISPOSED of something you were not supposed to do and then when the system tried to do it the error occurred?
Dave Figurski
