Where to get a working NXSigningResource.res file
The NXSigningResource.res found at C:\Program Files\Siemens\NX 10.0\UGOPEN appears to be empty.
The only contents are: NXAUTHBLOCK which gives me the impression that file is just a placeholder and that a correct file should come from some other source.
I have an NXOPEN development license, so I am guessing I need to do one of 2 things:
  • Download a proper NXSigningResource.res from somewhere.  If so, where?
  • Get an license in addition to NXOPEN development, that will let me sign and distribute.  If so, what is that license
Can anyone offer some guidance?
Re: Where to get a working NXSigningResource.res file
The resource file you have is OK.
Here is the link to documentation explaining what you need to do.
https://docs.plm.automation.siemens.com/tdoc/nx/10/nx_api/#uid:signing_process
Suresh
The problem is fixed now.  My error was in using SignCPP when I should have been using SignDotNet.
I will offer this warning for others:
If you use SignCPP on a dot net application, it will appear to succced.  It will even verify ok.
then when you try to run it you get a signature failure.
