Windows RMB step translation
many years go I found a bat file and a regedit on the old BBS that put a iges and step to ug translate open on my windows RMB open option.
any chance someone has that handy?
Rob Newcomb, Design and Engineering manager
Elmhirst Industries, Specializing in Prototype sheet metal stampings and assemblies
Production: NX 12.0.2 / Autoform r8 /WorkNC 2020.0
Testing:NX 1855
PC: Rave Cadbeast: Intel(R) i7-4790K CPU @ 4.GHz /32gb ram /NVIDIA Quadro P2000 on Win10 Pro
3 REPLIES 3
Re: Windows RMB step translation
The commands to add ug_convert_part to the RMB are in this thread. You may be able to do the same with step.
Mark Rief
Retired Siemens
Please find attached .txt (rename to .bat)
i use "ugnx_cad2prt.exe" (prt to step)
Modify according to your choice the variable %ext% ( step to iges)
set ext=step
set unit=mm
On windows 7 i use defaultprogramseditor.exe to modify the values of the register
Production: NX11.0.2.7,VERICUT 8.1.2
Development: Tcl/Tk, Gnuplot
www.adgroupe.com
I was looking for the other way around. STP and Iges to NX.
I found a solution in the CAM forum, I'm going to try to edit it to do iges as well.
import step bat file
Testing:NX 1855
