Writing to a text file instead of the listing window.
Innovator
Innovator
How do you write to a text file instead of the listing window using
Session.Information.DisplayObjectsDetails(NXObject[] objects)
Re: Writing to a text file instead of the listing window.
Honored Contributor
Honored Contributor
The following article has an explanation.
http://nxjournaling.com/content/write-text-file
Innovator
Innovator
Thank you.
To quickly document the answer here in case the external link goes stale and/or for searchability, use ListingWindow.SelectDevice() to direct the contents of the listing window to the window, a text file or both
Honored Contributor
Honored Contributor
The main thing to remember when using the listing window to write to a file is that you need to "flush the buffer" by changing the output device to something else after writing your information. Otherwise, the information may not be written to file.
What info can you get from DisplayObjectDetails that you can't get from other API functions? Digging through a mass of text to find the info you need seems pretty painful.
山田
yamada
