a trouble in select object in .Net VB
Hi
I got a problem that I got the solid body from "select object" UI in Block Styler, and I want use Modl.AskBoundingBox to calculate the size of the solid body, how can I transfer TaggedObject to Tag? Or maybe I have something wrong in below program?
Dim body As NXOpen.Tag
Dim taggedObjectVector() As TaggedObject
taggedObjectVector = Me.selection0.GetProperties.GetTaggedObjectVector("SelectedObjects")
Try
UfS.Modl.AskBoundingBox(body, boundingbox)
x = boundingbox(3) - boundingbox(0)
y = boundingbox(4) - boundingbox(1)
z = boundingbox(5) - boundingbox(2)
Best Regard
Christian
Best Regards
Christian
Re: a trouble in select object in .Net VB
Every object has a tag property, so you just use that property, like MyBody.Tag Smiley Wink
Hi Stefan
I'm still confuse with tag property, can you give me more hint? Thanks in advance!
Best Regard
Christian
Best Regards
Christian
For Each theTaggedObject As TaggedObject In taggedObjectVector
    UfS.Modl.AskBoundingBox(theTaggedObject.Tag , boundingbox)
Hi Stefan,
I got it, I appreciate you could tell me the detail program, thank you so much!!
Best Regards
Christian
