centralized settings for STEP import
We are using NX and at this moment I like to import an assembly from a STEP file and continue working on all components for setting up drawings using the master model approach. For setting up the drawing we use attributes in our modeling template (stored in network folder) and by default the STEP translator does not use the model template for components and therefor these attributes are not available.
I found the thread about "import step assembly to the modeling template" and this has been helpful as a starting point to fix this on one machine. The remaining issue is how can we use this for all work stations, is there a way to have the settings for STEP import refer to one model template that is on a network folder? We already use a .bat file to fire NX and set the template location to one network folder. Does anyone have experience with the STEP file issue? Thanks in advance...
Best regards,
