control height of a dialog box?
I have a simple dialog box that I would like the height to display larger than it currently does. In the Block UI Styler there is a Dialog Sizing property that can be set to Allow Resize or Follow Policy. Not sure what this property does but it doesn’t seem to change anything. Changing the Height property of the tree control on the dialog will change the size at design time but does not carry through at run time. The dialog box shrinks down and a scroll bar appears on the tree control. How do I control the height? Most important the height of the tree control?
