error when the part is later closed
I have created an UDOFeature by programming in NXOPEN.
Also Using the method >NXOpen::Annotations::PmiNoteBuilder:CreatePmiNoteBuilder
I have created a note and linked to >that UDOFeature. But I got following error when the part is later closed. Error message-"An embedded object cannot be deleted in isolation" Please let us know if more information is required.
Re: error when the part is later closed
1. The tool created some NXObject which cant be deleted.
2. Try destroy all Builder that you used in the tool.
::Smiley SurprisedPTIMUS_PRIME
Thanks for your reply.
Can you please elaborate more?
From your reply we have already  destroy all Builder that we used in the tool.
But issue is still present.
Hi ,
Did you get the solution for your ticket ?
I am also facing same issue.If u find the solution please let me know.
Thanks.
After creation of pmilabel using pmiNoteBuilder.CreatePmiNoteBuilder, you must call destroy function after creation.
pmiNoteBuilder.Destroy();
