get expression of suppresed component by "suppress by expression"
Hi All,
My journal cycles the assembly and detects if the components are suppressed.
I'm able to detect if the component is suppressed by expression by reading the errorlist.
But I need to get the expression that steers the suppression.
Any ideas how to get this expression?
Fred
Sub UnsuppressComponent(cmp1 As Component)
        'unsuppress this component
        Dim errorList1 As ErrorList
        errorList1 = cmp1.Unsuppress({cmp1})
        If errorList1.Length > 0 Then
            For ii As Integer = 0 To errorList1.Length - 1
                'suppressed by expression
                Dim errInfo As ErrorInfo = errorList1.GetErrorInfo(ii)
                lw.WriteLine(errInfo.ErrorCode)
                lw.WriteLine(errInfo.Description)
                If errInfo.ErrorCode = 650027 Then
                    '????HOW TO GET EXPRESSION NAME????
                End If
            Next
        End If
        errorList1.Dispose()
    End Sub
Frederik Verscheure
Evolve Consulting bvba
Freelance NX & Teamcenter consultant
frederik@evolve-consulting.be
3 REPLIES 3
Re: get expression of suppresed component by "suppress by expression"
I've not used it, but I'd give the .AskSuppressionExp method a try.
Here's a quick example:
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Module Module1
    Dim theUfSession As UFSession = UFSession.GetUFSession()
    Dim lw As ListingWindow = theSession.ListingWindow
    Sub Main()
        If IsNothing(theSession.Parts.BaseWork) Then
            'active part required
            Return
        End If
        Dim workPart As Part = theSession.Parts.Work
        lw.Open()
        Const undoMarkName As String = "suppression expression name"
        Dim markId1 As Session.UndoMarkId
        markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, undoMarkName)
        'process top level components of the display part
        For Each tempComp As Assemblies.Component In theSession.Parts.Display.ComponentAssembly.RootComponent.GetChildren
            lw.WriteLine("component name: " & tempComp.DisplayName)
            If tempComp.IsSuppressed Then
                Try
                    tempComp.Unsuppress()
                Catch ex As NXException
                    If ex.ErrorCode = 650027 Then
                        'component suppressed by non-constant expression
                        'get instance of component
                        Dim instanceTag As Tag = Tag.Null
                        instanceTag = theUfSession.Assem.AskInstOfPartOcc(tempComp.Tag)
                        If instanceTag = Tag.Null Then
                            'skip this
                            Continue For
                        End If
                        'get the suppression expression tag
                        Dim expTag As Tag = Tag.Null
                        theUfSession.Assem.AskSuppressionExp(instanceTag, expTag)
                        Dim suppressExp As Expression = Utilities.NXObjectManager.Get(expTag)
                        lw.WriteLine("  suppression controlled by expression: " & suppressExp.Name)
                    Else
                        lw.WriteLine("error " & ex.ErrorCode & " : " & ex.Message)
                    End If
                End Try
            End If
            lw.WriteLine("")
        Next
        lw.Close()
    End Sub
    Public Function GetUnloadOption(ByVal dummy As String) As Integer
        'Unloads the image immediately after execution within NX
        GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately
    End Function
End Module
Hi Cowski,
Thanks for the quick reply. I was planning on testing the journal today but copying your sample code is even faster. Smiley Happy
Thanks again for the great support!
grt
Fred
Frederik Verscheure
