how to change operation name and cycle parameter using journal
hi, I had created a journal to create bundle of operation of drilling.
Select the specific hole type then it will create all the neccessary tools and operations and set the respective FEEDS and RPM repeatedly until user click OK or cancel button. The problems:
1) operation did not created after click the apply button, all the operations will show at the same time only after the OK or canceled button was click
2) how to rename the operation name?
3) how to set other data under cycle parameter like depth, step value?
I'm not an expert in VB, so please do take a look of my program's structure?
thank you
SC
NX 10.0.3.5, WINDOWS 7
Re: how to change operation name and cycle parameter using journal
Siemens Legend Siemens Legend
Siemens Legend
Just want to check if you are aware of Feature Based Machining in NX ?
Reinier Capelle
NX CAM Development - Customer Success
Yes, but our data mostly on 2d. Does it work on 2d drawing?
You can tag 2D geometry as hole features for use with FBM.
Supported are points (regular points, points of curves, etc.) and arcs.
