how to collect objects from Unused Items
I tried to use the following to collect all objects from the program order view:
 Dim ncgroups As NCGroupCollection = workPart.CamSetup.CAMGroupCollection
 Dim ncgroupsArray As NCGroup() = ncgroups.ToArray()..but objects from the Unused Items was left out. How to collect all objects including those from Unused Items?
achuan
NX 9.0.2.5
NX 10.0.3.5, WINDOWS 7
Re: how to collect objects from Unused Items
By design, objects in unused items are ignored in CAM, so I think you need to explicity look in the NONE group.
I have a program moves objects to the unused group in all 4 views - perhaps how the "NONE" group is referenced here will help you:
    Function action(ByVal camObjectTag As Tag) As Boolean
        Dim camObject As NXObject = NXObjectManager.Get(camObjectTag)
        Dim WorkPart As Part = TheSession.Parts.Work
        'Check if the object is an Operation
        If TypeOf camObject Is CAM.Operation Then
            Dim operationType As Integer
            Dim operationSubtype As Integer
			Dim objectsToBeMoved1(0) As CAM.CAMObject
			objectsToBeMoved1(0) = camObject
			Dim nCGroup1 As CAM.NCGroup = CType(workPart.CAMSetup.CAMGroupCollection.FindObject("NONE"), CAM.NCGroup)
			workPart.CAMSetup.MoveObjects(CAM.CAMSetup.View.Geometry, objectsToBeMoved1, nCGroup1, CAM.CAMSetup.Paste.Inside)
			workPart.CAMSetup.MoveObjects(CAM.CAMSetup.View.ProgramOrder, objectsToBeMoved1, nCGroup1, CAM.CAMSetup.Paste.Inside)
			workPart.CAMSetup.MoveObjects(CAM.CAMSetup.View.MachineTool, objectsToBeMoved1, nCGroup1, CAM.CAMSetup.Paste.Inside)
			workPart.CAMSetup.MoveObjects(CAM.CAMSetup.View.MachineMethod, objectsToBeMoved1, nCGroup1, CAM.CAMSetup.Paste.Inside)
        End If
        Return True
    End Function
Mark Rief
Retired Siemens
Esteemed Contributor
FindObject with NONE will find any of the four unused groups, if you like to find a specific one depending on the view, you would need to use CAM.CAMSetup.GetRoot(), CAM.NCGroup.GetMembers() and check for the name NONE.
Got it.
achuan
NX 9.0.2.5
